wireless signal strength (more accurate reading than windows)
Sep 12, 2006 1 Replies
Hi
Is there a piece of software that I can use on WindowXP to walk around my home and find strong signal areas for wireless routers? Like KissMac for MacOS?
Regards
NETSTUMBLER is the one. Free. When it works, it's great!
Does not work with all cards/adapters.
I must say, I wish it would work consistently for me. It does not seem to deal well with windows XP zero configuration or something, though as I understand it, that's what it's designed for. It worked for a few weeks for me, then got broken somehow. Sometimes it shows no signal, other times no AP at all, then I turn on XP wireless again and the AP comes right up.
On the "help" and the manual end, there is almost nothing. Wish somebody would do a tutorial. Has a forum, (stumbler.net?) but it appears to shun beginners.
Try it and see!
