WEP to WPA
Jan 10, 2008 2 Replies
Finally got around to securing the home network with a LinkSys WRT54GS. The LinkSys monitor advised to move from WEP for speed and security reasons which I did.
My work machine and my wife's laptop work fine but the 'ol Toshiba laptop (A55-S3063) will not connect with WPA2-PSK. That Authentication type is not in the drop down. I (think I) have installed all applicable updates.
Any ideas? Thanks in advance.
JR
On Thu, 10 Jan 2008 15:21:50 -0500, JRHill wrote in :
  1. Get a wireless adapter that supports WPA2-PSK.
  2. Use WPA "classic" instead.
probably a pre WPA card........
change it out for a newer model. They are normally located under one of the bottom covers.
