Weird problem with 3COM wireless card
Nov 17, 2006 5 Replies
I have a 3Com 3CRWE154G72 wireless card. I am using windows 2000 and the latest drivers. The card was working fine, and had now started to stop connecting to networks. If you scan, ti will find networks for about 1 min, then stops finding any. It is impossible to connect to any. I get code 10 errors once the device has stopped finding networks on scanning.
I have tried driver reinstalls and reinstalling windows. No joy!
Any ideas!?
Thanks squelch41
On 17 Nov 2006 14:30:08 -0800, snipped-for-privacy@hotmail.com wrote in :
Make sure all power management is disabled. Scan computer for viruses and spyware.
Nothing on the scan. Power management for the card is disabled - no joy!
John Navas wrote:
Just to compound this, when I boot up, if I go to device manager, there is no code 10 error on the wireless card.
Once it had stopped recognising networks (as I say, takes about a min) then the code 10 error appears on the device.
snipped-for-privacy@hotmail.com wrote:
I presume you followed the instructions, and installed the drivers BEFORE installing the card? Apparently this often causes issues.
Also there are some comments about these cars on dslreports.com. A google search for 3CRWE154G72 code 10 error might be instructive.
I have followed the instructions an dodne the things in order - been burnt by that before (other devices in the past!).
I am beginning to wonder if the card has failed or if it is due to a secruity update knackering the drivers - have tried to install it onto a friends laptop that runs XP - same problem.
Tried google but all the responses are just the obvious things I have already tried.
Will look on dslreports.com.
Thanks for your help
squelch41
Mark Mc> >
