WAP54G firmware upgrade goes awry
Jun 18, 2006 23 Replies
On Sat, 01 Jul 2006 10:03:18 -0700, Jeff Liebermann wrote: : John Navas hath wroth: : : >Access points (unlike routers) don't query DHCP servers because they : >don't care about IP addresses. They are simply bridges that just pass : >data link layer traffic back and forth, including DHCP traffic from : >clients talking to DHCP servers on the other side of the bridge. The : >management interface address of the access point is set manually, not by : >DHCP. : : I beg to differ. Although the default setting is usually a static IP : address, most access points allow the IP address to be set via DHCP. : : For example: : : DLink DWL-2100AP: :
: : DLink DWL-7100AP: :
: : Dlink DWL-900AP+: :
: : Sorry, no Linksys examples until
comes back. : My foggy memory seems to vaguely recall that these also support IP : address setting via DHCP.
I'm pretty sure that all current Linksys APs, and the WAN side of all their current routers, support DHCP. I've used several, and they all did.
: The problem is what to do about the gateway IP address. Note that the : default value for the gateway on the above examples is blank or : 0.0.0.0 which means no default gateway.
In the WAP54G it's 192.168.1.1 (which, probably not coincidentally, is the default LAN-side address of most Linksys wireless routers). The default address of the AP itself is 192.168.1.245, for no obvious reason. Each Linksys model seems to go with a different randomly chosen number in the fourth octet.
: That makes sense as you would : not want your return packets going off to the internet when they : should be going to whatever IP is originating the packets. The only : time one needs a real gateway IP is when the access point needs to get : or send something to or from the internet. That can be time sync, : update checks, logging output, and possibly DNS lookups. Otherwise, : no gateway is required or desired.
Well, that's assuming you have a flat network. Our network is broken up into about a dozen subnets, so the probability that a given packet has to go through the gateway is pretty high.
: Another uncommon problem is what to do if the gateway IP address : happens to be outside of the netmask IP address range. This can : happen if the LAN is divided into subnets. All current desktop OS's : support this, but it seems to be lacking in commodity routers and : access points. It's not a big problem but should be consdered for : complex network topologies. (The easy solution is to alias the : internet gateway router with a LAN gateway IP in each sub-net).
That doesn't happen. The gateway address recognized by the access point represents only the next level up the subnet tree. So it's always within the AP's local address space. It's up to the gateway router's WAN side, which the AP doesn't see, to figure out how to traverse the next step towards the Internet.
Admittedly I'm ignoring the existence of source-routed packets, but a cheap AP (which in any case is unlikely to have a choice of gateways) is almost certainly not going to look at the embedded routing info.
On Sat, 01 Jul 2006 10:03:18 -0700, Jeff Liebermann wrote in :
You are correct, as I noted in an earlier response.
Here I beg to differ. A network bridge doesn't have anything to do with IP addresses since it operates on the data link layer. Thus a gateway address and netmask aren't meaningful to the bridge, especially since they won't necessarily be related to the proper port. In other words, they are only meaningful to the management module. The correct thing for the bridge to do is to either learn the correct port from the incoming Ethernet management frame, or flood the response to all ports, initially at least, learning which port to use for future responses, just as it does with all other network traffic.
Generally true for most consumer access points and bridges. Wwrong for the better bridges and access points. The higher end devices all have syslog, ntp, snmp, smtp for emailing log files, dnsmasq, and other services that usually require internet access to work. Without these, the bridge would not need a gateway to the internet as in a typical commodity access point. But, with these services, a functional gateway is a requirement.
Another example is the typical print server. Many of these can automagically check for firmware updates from the internal web based admin interface. However, that doesn't work unless the default gateway is configured and functioning. Of course, if IPP (internet printing protocol) is being used, the gateway is manditory.
Management and services features.
I don't think a bridge can determine the default gateway by this method.
On Mon, 03 Jul 2006 19:49:18 -0700, Jeff Liebermann wrote in :
Sure, but those are management services that aren't really part of the bridge -- the management module is functionally separate (and is even physically separate with some devices), and a gateway is only necessary when leaving local subnets by means of a router, which isn't true in many cases.
Right, but not part of the bridge.
True, but it will work fine when the source is on a local subnet, as it often is. I personally think it's a bad idea to have network hardware devices making non-local connections on their own.
