USR Router8054 + Repeater5450
Apr 17, 2005 3 Replies
Jump to replies (3)
Hello, I have placed a USR-Router8054 to cover the wireless connection in (let's call it) "ZONE1" and a Repeater5450 in "ZONE2". The latter with the latest FW (1.41). Everything is working ok, with WEP activated in open system. The only oddity is:
1.when I have a laptop connected in ZONE2 and walk to ZONE1 the connection seems still ok (signal strenght), but if I try to browse the internet or the LAN it is NOT. If i popup the wireless status windows from the taskbar and I do a restore (the system shuts down the connection and restart it) it starts to work again.
2.The same behaviour if I walk from ZONE1 to ZONE2 doen not happen!
Do you have any explanation and solution to this irritating and boring fault?
Thanks a lot.
Apparently, USR is not a popular brand name, although I find their routers to be very good. I suggest that you get in touch with USR Tech Support about the issues you are having with the device.
Duane :)
