Users connected to an Access Point
Sep 06, 2007 3 Replies
Jump to replies (3)
Hello, does anybody know if there is a tool to easily detect all the PC's (their IP & MAC) that are connected to a wireless access point and what bandwidth each is using?
Thank you very much
Panos
~ Hello, does anybody know if there is a tool to easily detect all the ~ PC's (their IP & MAC) that are connected to a wireless access point ~ and what bandwidth each is using? ~ ~ Thank you very much ~ ~ Panos
Assuming that you are using a Cisco Aironet AP, then just use the command "show dot11 associations all-client".
Assuming that you don't know what kind of AP you have, then there is no general answer to your question.
Aaron
Panos hath wroth:
Such information is usually extracted directly from the wireless access point via SNMP or proprietary managment software. Sniffing traffic between the wireless access point and router will not yield this information. Some clue as to what you have for hardware might be helpful.
Aaron Leonard hath wroth:
Bah-humbug. Use SNMP instead. Using SNMPUTIL.EXE from:
pointing to my WRT54GS running DD-WRT v23 SP3:
List of connected IP addresses: snmputil walk 192.168.1.1 public .1.3.6.1.2.1.3.1.1.3.1.1 which returns:
Variable = at.atTable.atEntry.atNetAddress.1.1.63.249.85.1 Value = IpAddress 63.249.85.1
Variable = at.atTable.atEntry.atNetAddress.1.1.192.168.1.11 Value = IpAddress 192.168.1.11
Variable = at.atTable.atEntry.atNetAddress.1.1.192.168.1.51 Value = IpAddress 192.168.1.51
Variable = at.atTable.atEntry.atNetAddress.1.1.192.168.1.113 Value = IpAddress 192.168.1.113
Corresponding MAC addresses: snmputil walk 192.168.1.1 public .1.3.6.1.2.1.3.1.1.2.1.1 which returns:
Variable = at.atTable.atEntry.atPhysAddress.1.1.63.249.85.1 Value = String
Variable = at.atTable.atEntry.atPhysAddress.1.1.192.168.1.11 Value = String
Variable = at.atTable.atEntry.atPhysAddress.1.1.192.168.1.51 Value = String
Variable = at.atTable.atEntry.atPhysAddress.1.1.192.168.1.113 Value = String
