use Linksys WRT54G as access point off of Firebox Edge?
Jul 17, 2005 3 Replies
Bryce
I'll give it another shot then. Since somebody has done it, obviously I've just set something up wrong. Thanks. Bryce.
I've got my firebox as 192.168.111.1 and I gave the Linksys 192.168.111.5. I still can't access the Linksys.
When I hook directly up to it I can access it.
Do I need to put it in bridge mode or something?
Can I use it as an access point?
Thanks.
Bryce.
Thanks.
Bryce.
"Bryce" wrote in news:1nvCe.8$ snipped-for-privacy@news.uswest.net:
All I did was disable DHCP on the BEFW11S4 v1 router, set the device IP to
192.168.111.2, took the router out of *gateway* and put it into *router* mode, configured the router to use static the IP set-up pointing to the WG at 192.168.111.1 -- not using DHCP setup that would be to obtain IP from the WG for the router, and connected it to a LAN port on my WG Firebox III SOHO 6. I could access the Linksys router at 192.168.111.2 with the browser.
The Linksys just became a wire/wireless AP *switch*.
Duane :)
"Bryce" wrote in news:eUwCe.393$ snipped-for-privacy@news.uswest.net:
The above is in the link below.
You can use it as a guide.
Duane :)
