Topcom WBR611 unable to reset
Jul 22, 2005 0 Replies
I'm using a WBR611 access point as a single router in my home network. One central pc having access to internet is connected with a cable (rj45) and the other ones are using wireless connections to the router.
I made a mistake by allowing only the MAC adresses of the wireless network cards of the other c but I miss to enter the mac adress of the central pc. So just after the "apply" the router was no longer accessible for administration purpose.
I tried to reset the router in order to return to the initial factory settings but it seems this is no longer possible.
Should anybody already experienced something like that?
Thanks for your help
Christian
