static ip at home dhcp for everything else
Aug 31, 2005 2 Replies
static ip at home dhcp for everything else open original image
Hi all,
I have a wireless network setup at home where I use static IP for all my machines for certain reasons. However, whenever I take my laptop somewhere, I need to change from static IP to DHCP and it is a pain to set it up for static IP when I get back home. All the info for the static IP disappears once switching to DHCP and I have to re-enter it all. Is there a simple way to have a static IP at home, and have windows use DHCP automatically everywhere else? I'm hoping I can use something native to Windows XP and not something like "Net Switcher" software. Thanks.
snipped-for-privacy@hotmail.com wrote in news:1125519024.545702.33460 @g44g2000cwa.googlegroups.com:
You may be able to do something with it.
Duane :)
Yes it is already built into Windows XP.
Configure the main IP address to be DHCP but then on the alternate address, configure the static IP address that you need at home.
When XP fails to lease a DHCP assigned address, XP will then choose the static configuration you have defined.
David.
