share 2 networks
Oct 27, 2005 4 Replies
Jump to replies (4)
Why don't you just take your laptop over there and find out? If it works, then, yes, you just need to put a card in his machine. If it doesn't then you'll have to give us a whole lot more information.
I have a wireless access point, 4 pc on a network all wired just the laptop uses the AP.
My M8 50m away has a network wired, we wish to play LAN games and share a couple of files.
Do we just need to stick a wireless pci card in one of his machines?If so can you point me to some online info or say how to go about it.
Cheers Chris
It certainly can, though I run linux, so can't help you on setup.
: > My M8 50m away has a network wired, we wish to play LAN games and : > share a couple of files. : >
: > Do we just need to stick a wireless pci card in one of his machines?If so : > can you point me to some online info or say how to go about it. : : Why don't you just take your laptop over there and find out? If it works, : then, yes, you just need to put a card in his machine. If it doesn't then : you'll have to give us a whole lot more information. : -- : derek
Yeah there's not a problem with signal that is ok. It's can a PC have 2 network cards 1 wired and the one we wish to add wireless,would we need any add software ect.The machine we wish to add the card to is running 2kpro.
Cheers Chris
Just buy a PCI or USB donglw WiFi-g adaptor off eBay, dirt cheap (make sure it's WPA encryption-capable) . Plug it in to the PC and off you go. My laptop has wired and wireless adaptors that I use simultaneously.
