Security with Netgear 614 WPA + TKIP
May 08, 2007 1 Replies
I friend of mine just got a netgear 614 that only had WPA + TKIP available as its highest option. I turned off SID Broadcasting. I had hoped netgear would ship these routers with WPA2 + AES, maybe there is a firmware I don't know about. Is the security sufficient or should I try to get them to get another router.
Thanks, Pete
On 7 May 2007 23:18:48 -0700, Peter wrote in :
That won't help. Leave SSID broadcast on.
WPA is sufficient.
