"simple matter"
Yeah, right. ;)
Netgear RP614 router. Under the LAN configuration menu there are, among others,...
Hi, of course you can... just specify on dhcp server excluded addresseswhich you...
Is there a 802.11g wireless router that allows DHCP to assign other than class C...
You are reporting this content to the moderators.They will look at it ASAP.
