Lost Ability to Connect Wireless After IE Upgrade
Oct 28, 2006 1 Replies
I downloaded and ran the IE7 setup on one of our laptops and now it cannot connect to our wireless home network. it see the network fine but cannot make the connection. The laptop is a Dell Latitude D820 with the Intel pro wireless and bluetooth. Any suggestions appreciated.
IE7 -> File Uncheck "Work Offline".
How can you "see the network fine" and at the same time "cannot connect to our wireless home network"? Can you browse the internet? Can you see other computers on your WLAN/LAN with: Start -> run -> cmd net view What does Intel Proset or Windoze Wireless Zero Config status show?
