Linksys Wireless-G Range Expander
Dec 10, 2004 5 Replies
Jump to replies (5)
I have a D-Link Dl-624, could anyone please tell me if the Linksys Wireless-G Range Expander will work with this router, thanks.
No it won't. I believe the range expanders are CNC connectors and the DLinks are not.
sean
The range expander is a repeater, so what does its antenna connector have to do with anything? To the original poster, frankly you could buy one from someplace that has a fairly liberal return policy and test it out. If it works, keep it, if not take it back.
That's what I did and it didn't work.
Thanks for the reply.
I don't have much choice but to use WEP. I have to use on main AP/router plus two repeater APs to get a good signal thoughout my whole house :(
I have one and it works fairly well however it won't yet support WPA encryption so I am not currently using it. It will support no encryption or WEP encryption.
Dave G
