Is it possible to lock speed for a wireless connection?
Mar 26, 2005 5 Replies
Ed Williams
Usually you can click on icon in system tray and wireless network settings change transmission rate from automatic to what you want.
Hello!
I seem to notice if my wireless speed goes higher than 2.0 Mbps on my Hawking Technology's Hi-Gain USB Wireless-G Adapter (Model: HWU54D), I get major packet losses to the D-Link DI-624 wireless router (192.168.0.1).
Is there a way to lock this 2.0 Mbps speed manually? I do not want the wireless connection to change (e.g., going up and down). I want it to stay at 2.0 Mbps (sweet spot). I don't care about the speed, I want stability. I am using Windows XP Professional SP2 and the latest driver from Hawking Technology.
Thank you in advance. :)
The only thing I see is the current Mbps speed, but nothing to change. This is both in Windows XP SP2's wireless options and Envara Configuration Utility. Did I miss anywhere else?
Ed Williams wrote:
You might have to go under control panel, the system, then hardware to the device.
I don't see anything about speed there. :(
I see: Config file Country Code IBSS Orginator BeaconPeriod IBSS Orginator Channel IBSS Orginator Phy-Mode Network Address Station RtsThreshold Station ScanPolicy Tag
Nevermind this request. I got packet losses again even at 2.0 Mbps, and my speed went down to 1.0 to be stable. Wow. Oh well. Thanks to all who replied. :(
