I've lately picked up an interest in wifi, mainly, as an option to untangle myself from cables. As an amateur radio hobbyist, I understand the principles of the radio hardware involved but not the firmware/software aspects of wifi. I can save that for later. The question I have is about the antenna system. I've seen several DIY parabolic contraptions you can make from cardboard and aluminum foil to place on the 'antenna' to increase the range and directional characteristics. With the transmitters I'm familiar with, you just can't start modifying the antenna system, with no regard for SWR. Could someone explain if SWR is critical to a wifi transmitter? I'm assuming since they appear to be a relatively low power device, they can either tolerate a high SWR or have built-in protection. I'm not so concerned with SWR as it relates to the efficiency of the antenna system but more with the potential to cause damage to the transmitter.
For the most part, you are correct. If you change nothing but the output power...
C
Chuck Olson
I suggest you might find more satisfying answers if you pose your question on the "rec.radio.amateur.antenna" newsgroup..
For my own education, I bought a Wi-Spy USB spectrum analyzer module, set it in a shield enclosure, and made measurements of various antennas as receiving devices. This approach is easier than trying to make SWR measurements on antennas as transmitting devices. You can find SWR bridge construction for 2.4 GHz on the web, but in the end only results count. Leave the SWR problems and protection to the chip designer with a laboratory of expensive test equipment to guide him. Certainly standard configurations of simple antennas will behave fairly predictably - - for instance, use a folded dipole as the radiator in a 23-element Yagi design, because you know the parasitic elements will knock down the feed impedance to something you can use - - that sort of thing. There's a lot of information on Wi-Fi antennas on the web, and I built most of the designs myself. The worst result was from the "helical" type, and the best result was from the "quarter-wave radiator in a tin can waveguide" and from the "Biquad" configuration.
Good luck
Chuck W6PKP
J
Jeff Liebermann
awizardalso hath wroth:
Good observation. Most antenna builders don't bother with VSWR, running simulations, field testing, and all the niceties of calculations and measurement. There are several reasons for this (in order of decreasing importance).
Any antennna is better than the stock antennas that come with the typical router. Even if the VSWR absolutely sucked, it would constitute a substantial improvement gain. For example, compare these two biquad antennas: (good) (bad) Numerous web piles show both methods of construction. The 1st has a gain of 11dBi with a VSWR of appprox 1.5:1. The 2nd has a gain of 11dBi with a VSWR of 6:1. Yech. The first is properly designed and constructed. The 2nd is a feel line problem between coax and the quad elements. However, the gain is the same, so nobody notices or cares.
Crude is effective. You can build a wi-fi antenna fairly crudely, with miserable tolerances and crude construction techniques, and still end up with something that's better than the stock antennas. I'm used to squeezing the last dB of gain out of the antenna, so my first impression was very unfavorable. I'm used to precision machining, but have learned to tolerate cardboard and aluminum foil. After building and testing some antennas, I find that the average user doesn't need that last dB.
Test equipment is expensive and difficult to build and calibrate.
It can be done, but requires precision beyond what the average user is willing to pay for. (Incidentally, look at the AMOS sector antenna on this page for a really good and easy wi-fi antenna)
VSWR is only a major issue with high gain ( >15dBi ) antennas. That's because the VSWR bandwidth tends to get narrow as the gain increases. Above some gain ( 24dBi???) the bandwidth gets sufficiently narrow that the antenna has to be tuned to a specific group of channels and will not cover the entire band.
Transmitters are very tolerant of high VSWR. All power amp MMIC's have built in VSWR protection so there is not going to be any blown amps. Most are also fairly conservative, running at 50mw out on a
250mw spec power amplifier. If I were running 1 watt, I might be concerned, but even those have VSWR protection.
Gotta run....
Report Content
ASAP.
