HP 2510 PSC WPA Wireless setup
Dec 11, 2004 2 Replies
HP 2510 PSC WPA Wireless setup open original image
Hello,
I have recently got broadband and decided to share my connection wirelessly and securely. I've been having problems setting up the printer to connect to my wpa-psk network. Doing a search on the network I realise I'm not the only one. Did anyone have a solution for it. The problem is not with the network or PSK. and I have made sure the wireless router supports both b and g so should pick up the printer.
From what I read the on another site the printer acknowledges but doesn't come online. I'm just trying to find out if there was a solution?
thanks,
Daniel
I don't think the HP 2510 works with WPA just WEP.
Well one of the only useful articles I can find is
and I did find one where someone contacted HP Without much luck ( possibly from this newsgroup). But I've not found a definitive answer...
I think I'll just share the printer from my pc which is sitting next to it anyway, probably easier, just requires that pc switched on!
Thanks,
Daniel
