high cpu usage - dlink dwl-g510
Dec 03, 2006 2 Replies
i am having strange problem with my dlink dwl-g510
everytime i use wifi my cpu usage jumps to 100% an the pc is more less unusable. when i disable the card the load will get to normal (2-10 %) i noticed one thing - when i remove the antenna everything is normal (except the wifi signal is obviously lower). i installed the card in another pc and it behaved the same way. i called dlink several times - they keep saying that the problem in on my side (ie win problem, low memory[i have 512 mb] etc), and referring me to higher levels (currently waiting for L3 to get back)
tHanks for all ideas
forgot to mention that every other time I am not able to connect to my router at all
On Sun, 3 Dec 2006 11:25:32 -0500, "freightcar" wrote in :
Try a different wireless adapter.
