Hawking Hi-Gain USB Wireless-G Dish Adapter - HWU8DD
Feb 14, 2008 4 Replies
Jump to replies (4)
Thanks for the link, good price aswell!
- Home networking resource site, articles, reviews and guides.
Here's another one
JohnF
one
Great deal!
Personally, I would go with this one because having a replaceable antenna really opens up your options. You could put anything from a
10dbi panel to a 24 dbi dish antenna on it if needed for a loooong distance connection.
Also, with the included stock omni, you can put a reflector on it and get significant gain at no additional cost.
And all with the low cost and zero signal loss of USB extension cables !
Still the Hawking USB dish might be the best (simplest) option for certain applications.
Steve
one
That is a cool device!
