Extending range of wireless router
Sep 16, 2005 1 Replies
I have recently bought a 54Mbps 4 Port Wireless Cable/DSL Broadband Router/Access Point 802.11g by Safecom.
According to the website, it uses a 2 dBi antenna. As this is detachable, could I use a better antenna such as a 3 dBi to gain an extra 50% coverage in my house? Is the power output from the router enough to provide the extra coverage?
I am also thinking of buying a wireless repeater -
this also extend the wireless range or shall I stick to buying an antenna?
Thanks a lot... any help would be really helpful Sho
Antenna and you'll need 6dB gain to double the distance.
