Can surf, CANT FIND WORKGROUP!
Apr 26, 2007 1 Replies
NetSteady
Make sure that you have Client for Microsoft Networks AND Windows File and Printer Sharing listed under your Wireless Connection's properties. If not install them. My guess is that this will correct your issue. Otherwise, check your router to make sure that Wireless stations…
This seems to be an intermittent problem.
I have a computer using XP Home that CAN find the workgroup IF connected via cat5 but cannot if going wireless. I CAN surf without any problem. This is really confusing!
HELP
John
My guess is that this will correct your issue. Otherwise, check your router to make sure that Wireless stations can talk to LAN stations. Sometimes routers block this traffic by default.
Chris
