cable to connect wireless network card and antenna
May 04, 2006 1 Replies
Most relevant reply
Jeff Liebermann
Yech. The DLink WDA-2320 comes with an RP-SMA jack. The Rootena comes with an: "SMA-Female connector with MMCX cable" which was intended to be hot wired to an access point as in: what you need is a cable that has an RP-SMA plug on one end, and a normal SMA plug on the other. No…
Hello, I am new to all of this and am looking for a cable and hope you people can help me. I have a D-Link wireless network card which uses a "dipole with detachable reverse SMA connector" antenna. It works pretty good but I only get a low signal and I would like to boost my reception. I have a
2.4GHZ Rootenna which is described as having a "SMA-Female connector". Do you people know where to get a cable that will connect these 2 items? If so I would like to know about it. Thanks. The pieces of equipment in quesion are
*** Posted via a free Usenet account from
"Ben Boyle" hath wroth:
So, what you need is a cable that has an RP-SMA plug on one end, and a normal SMA plug on the other. No big deal.
This should work:
can also probably get WLANparts to make you a cable:
don't list the normal SMA plug, but I'm sure they can get one.
