And you can use USB extension cables to extend the distance with NO loss of signal, since it is digital on the USB cable.
Beginner needs help
Oct 19, 2004
Last reply: 21 years ago
I use a YDI USB-ANT 18dbi Flat Pannel with built in card, comes uith 2 FEET of USB cable, [spec's do change] you can extend it ti 75 feet i needed I found a used crank-up tv antenna mount [free] to use for tilt mounted it to a $26 Tv antenna rotator. I have a second USB-ANT for
$149 at home with same set u on my roof. I have over 200 access points. It would be nice to see people do some research before giving mixed u or wrong advice to a newbee. I also use a 6' [foot] dish with a 2 wat bi-directional amp through a SMC 200ma pcmcia card when I am camping LM-400 is not 1/2 inch in diameter, if someone sold you 1/2 LM-400 on more time "No research" Now I am sure someone is gong to say something about the "LAW" please do not bother as every person in the USA that access's any A without permission is braking the "LAW. Oh by the way the FCC lost ove
90% of their field instectors back when Ronny Regon was the Pres. The they would have to fine you, not easy, they tried back in `82 to fin my 2000 watt CB and came close but not close enought I need to do some tweeking on the 6'er. I am about 6 miles short o the Aussy 80 MILE Record. Have fun, be good Later DrVtac
research,research,research!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
