Hi, I wonder the need for ACKs at various layers. If the Network Layer has the ACK feature, why is the ACK mechanism required at the Data Link Layer too ? Any ideas ?
Thx in advans, Karthik Balaguru
~ Hi, ~ I wonder the need for ACKs at various layers. ~ If the Network Layer has the ACK feature, ~ why is the ACK mechanism required at the ~ Data Link Layer too ? Any ideas ? ~ ~ Thx in advans, ~ Karthik Balaguru The lower layer has better knowledge of the transmission…
Read the full replyHi, I wonder the need for ACKs at various layers. If the Network Layer has the ACK feature, why is the ACK mechanism required at the Data Link Layer too ? Any ideas ?
The lower layer has better knowledge of the transmission expecations of its link than do the upper layers. Therefore it can tune its retransmission scheme much more precisely to yield better performance.
For example, TFTP has a 5-second (let's say) ACK timeout, because it can make no assumptions about the latency of the underlying network path (which could be any arbitrary topology IP path.) However, 802.11 has a (let's say)
1 millisecond timeout, because it knows that its transmissions travel at the speed of radio waves, and never more than (let's say) one mile. Therefore, if an 802.11 transmission should be lost or corrupted in transit (a not uncommon event), the transmitter can resend after a millisecond, and so get the data through pretty quickly, despite the error.If 802.11 didn't retransmit, but you had to rely upon the upper layer to do the retransmission, you'd have to wait
5 seconds. The resulting throughput would be much worse.Quite some years ago, I recall reading _An Engineering Approach to Computer Networking_ by S. Keshav. Right now it's buried pretty deep in a box at my feet, but it might well still be worth a read. There's also Radia Perlman's _Interconnections_.
There's still a lot to be said for sitting down and reading a book or two.
Aaron
Okay !
Thx, Karthik Balaguru
