Access point fails with WEP
Feb 28, 2006 7 Replies
Jump to replies (7)
Hi all,
I have a Netgear WAG102 AP. It's in the middle of a big (circa 6500sqm) exhibition centre. The floor is a structure of square metal slabs, and the AP is underneath. There are a few pillars around, but the signal is excellent all over, even at the perimeter.
However, as soon as I switch on WEP, my client can't associate. This happens on my laptop in both Linux and Windows, and it's known to work with WEP with other access points.
I *can* still see the WAP in kismet.
Just wondering if anyone can throw me a clue.
Thanks,
Antony
The usual problem is wrong key format, ASCII versus hex.
Don't think so. I'm sure I set 128-bit and 26 characters. But I'll try again in the morning.
Try entering both keys in hex.
Hi, I have been running around helping freinds setting up wi-fi AP and WDS (wireless repeaters) and try securing them.
I find more times that they use the wrong format for the WEP keys, to use Hexadecimal characters you can only use (the numbers 0-9 and letters a-f) unless your documentation tells you otherwise.
And must be correct number of characters be it numbers or letter.
This method requires you to enter a 10 character Hexadecimal key for 64 bit WEP, and a 26 character Hexadecimal key for 128 bit WEP
check out this web site for help.
Ok. I didn't strictly do this. I entered a passphrase on the WAP which generated a 26-character hex key. Is this different from entering that
26-character key directly?
Hard to say. Just try exactly what I wrote.
That's fine, you did enter the same hex key on the cient didn't you?
You didn't actually state that you entered the key at both ends!
David.
