VoIP and FAXing
Jan 29, 2005 4 Replies
I am currently in search for a VoIP provider as SBC is the only land line solution in my area and I no longer like the way they treat their customers.
I'm leaning tward Vonage, but my question is, does any of the VoIP providers have issues when FAXing over the primary line? I know Vonage can add a dedicated FAX line for $9.99, but I don't do a lot of FAXing (maybe once a month). Having a second line would be a waste. Any help would be appreciated.
Thank you!
ATT CallVantage says to check with them before using a FAX as only certain types are supported.
Faxing is supported over the primary line. The dedicated fax line is so you have a dedicated fax number.
I have faxed on my one and only vonage line and have had no problem. I have a very simple Brother Intellifax
I have setup a fax-service at
for free. Only drawback is that it requeires a call to it at least every 4 weeks - I've setup my server to automatically send a fax every 3 weeks to ensure that ;-)
