Re: Cisco Transcoding
Oct 21, 2004 3 Replies
Jump to replies (3)
Is it possible to have one leg of a call on a Cisco AS5350 SIP using g711 and the second leg H323 using g729. Can the Cisco transcode from g711 to g729 and vise-vera and can the Cisco support on leg H323 and the other SIP. How would I setup my dial peers to transcode? Thanks
--Matteo
Hello,
No, Cisco AS5350 cannot do VoIP-VoIP calls. For VoIP-VoIP you have to use IPIPGW (but you cannot convert SIP-H323 with it). So the only option for you right now is tor setup PSTN loopback (e.g. connect port 0 with port 1 with a crossover cable) on your AS5350, so the call will go VoIP(SIP)->PSTN(port0)->PSTN(port1)->VoIP(H323). If you need instructions on configuring the PSTN loopback, there is a pretty good example in the PortaUM User Guide from Porta Software:
WBR, Andrew
Andrew, Is a IPIPGW a Cisco gateway? What is the Model number. Thanks
--Matteo
Andrew Zhilenko wrote in news: snipped-for-privacy@speakeasy.net:
Hello,
No, the link I sent you is a documentation for PortaSwitch. In the installation guide for PortaUM (unified messaging solution) page 25-26 is the detailed information how you can setup PSTN loopback on Cisco AS5300/5350 gateway for purposes of doing VoIP-VoIP calls.
WBR, Andrew
