Help about windows programming with DLL
Jan 30, 2006 1 Replies
Hi all, i have a problem programming C++ in windows environment with DLLs. In particular, with OpenH323.dll which is the windows binary of the MPL released implementation of the H323 architecture. I succesfully load the dynamic library but, once here, I do not know what to do for importing that dll classes within my c++ code. My IDE is eclipse and i program using the CDT plugin and the (GNU) mingw32 g++ compiler and library set. I would like to solve the problem on this environment because i would not like to switch developing with some visual stuff.
Waiting for a reply, i thank you all for your kindness and availability.
Nicola
wrong group posting !!!
btw u can look for the functions that are exported by that dll and see if some of them can create the objects for you.
thanks ravinder.
