Gizmo Rates?
Jun 27, 2006 4 Replies
Enzo Michelangeli
At they say "There are no additional charges to receiving calls, and it?s far cheaper for the folks who call you.". This seems to mean "no per-minute charges", and this makes sense considering that for a call-in number they charge ~3 to 4 dollar a month in subscription, and in…
I have been comparing Gizmo with Skype.
What is not clear is what the Gizmo rates are for incoming calls, USA, from land-lines and mobiles/cells.
I see it is about 1 cent/minute outgoing to land-lines/cells per minute plus the annual subscription rate.
But their web site only seems to show the incoming annual subscription fee but nothing on the per minute rate.
Are they the same?
DMK
At
they say "There are no additional charges to receiving calls, and it?s far cheaper for the folks who call you.". This seems to mean "no per-minute charges", and this makes sense considering that for a call-in number they charge ~3 to 4 dollar a month in subscription, and in some locations the caller has to pay for local calls.
Incidentally, services like
or
offer absolutely free call-in numbers (although limited to few locations). With ATA's or IP phones able to handle more than one account, you may combine them for receiving calls, and another provider such as Gizmo for dialing out.
Enzo
Seems that IPKall is Washington State only and Stanaphone (per its forums) only has area codes in NY.
Now, that' OK for some but I was looking for something in Eastern Ma, ie Boston and Vicin.
DMK
You might check out
. They are pretty good and cheap.
If you don't mind about two-stage dialing, you may also use the free PointOne numbers listed at
, then dial "1" followed by your Gizmo SIP number (1747xxxxxxx) and terminating with "#".
But unfortunately, I can't see any in Massachusetts: the nearest to you seems to be in Connecticut...
Enzo
