broadvoice unlimited europe, is it good?
Nov 06, 2004 5 Replies
Darrell Frappier
I've had BroadVoice for 10 days so far. We've made about 15 calls to Greece and 3 calls each to Paris and London. Every call has been very good, much better than Global Crossings and cheaper. No idea how the quality compares to other VOIP providers. The $24.95 plan includes…
how is Broadvoice with the unlimited plan for europe?
is really unlimited calls with only 19,99$ or 24,9$?
the quality of their calls is the same of other voip providers?
I mean, can we have a lower price and a better sound-quality of the codecs and transmissions? it could be possible?
thanks
I have been using it for nearly two weeks and it has worked great
Jonathan
The $24.95 plan includes more countries than the $19.95 plan.
Darrell Frappier Detroit MI N3JWJ darrell at frappier dot us
I have had them for almost a month now. Sometimes they are good quality,
but every week or two they seem to have some problems. For example
right now I have not been able to make a clear call for about 3-4 days.
When it works it is a really good deal. Vonage quality and reliability
is infinitely better though. Even when it works fine, the quality isn't
quite good enough to connect a modem through, but you can do this on
Vonage with no problems.
The only reason I switched away from Vonage is their retarded policy of
charging so dam much for the softphone usage. I don't want to carry
around that stupid box everywhere when I travel. Thats the whole point
of VOIP, wake up Vonage!
Anyhow, Broadvoice is much cheaper, they are nice and friendly too if
you ever reach a tech support person (this is the other difference from
Vonage, u usually can't get through to tech support unless u call at
like 3AM it just says leave a message and they never call back...).
Anyhow, yes it really is a really good deal, when it works. But often
it does not, and those users who posted good things above probably
havn't used it that much. Check other forums and posts and ppl will
tell you every week or two they have problems. I'm hanging in wiht them
to give them a chance to fix this.. If they dont' soon I'll ahve to go
back to Vonage because if I can't talk to ppl when I want to it doesn't
do me any good.
I agree Vonage charge for Soft_Phone, check iconnecthere.com they charge nothing for softphone and voice quality is very, thats my experience, I will try LINGO that have my area code.
Carlos
I have subcribed to "Broadvoice" today I have a Grandstream Handy-tone 286. What do you have? I will use and see their quality. The have my area code which is important. Carlos
