This is (should be) an easy question(!)
Is it possible to plug an ATA 186 in to a standard PABX and use it as one of the external lines? If not, what should I be looking for?
Thanks for your attention.
Thank you! Has anyone here actually done this? Am I out on a limb with this one? Is there a better way to do it (connect to a PABX)? Or is this just standard?
Read the full replyHi,
Yes.
it should work.
schreef in bericht news: snipped-for-privacy@f14g2000cwb.googlegroups.com...
I have done this with a VTA1000 from pcphoneline.com. This is basically the same idea, but the VTA1000 is an USB device. Flawless operation. (The VTA1000 supports SIP & Skype) In use since christmas in a commercial setting. Regards, Erwin.
Thanks very much for the assistance. I'll give it a try.
I've done it with Nortel Norstar systems, no problem.
miguel
Are you the one that programs the PBX? cuz, I guess I'd be wondering if your PBX is programmed or limited by ckt-packs to only ground-start lines?
I have the 186 in a home environment, so I'd be interested in hearing from others who might know if the 186 can be configured for ground-start supervision, as opposed to loop-start in the residential space.
From your question, I'm assuming that you're thinking of trunkside on the PBX.
Jon
