Adding custom options to DHCP scope
Feb 07, 2006 3 Replies
Jump to replies (3)
I need to add custom options to a predefined DHCP scope for our Mitel phones on Windows 2003 server. I've done this once before but misplaced my notes during our move. I can go into DHCP scope options and see and edit all the options but even in advanced there is no "add new". Can someone point me in right direction?
thanks
Hal
In the DHCP console expand the scope, there should be a "Scope Options" icon. Right click and select Configure Options The options show up in a dialog box. When you actually select an option you will be able to fill in the parameters
daveM
I have followed these instructions only to find that when I delete and add a predefined option, 132 and 133 which I must change for my Mitel phones, the options revert back to their default setting when the scope is restarted, any thoughts?
