Re: What About Areas Where Alphabet is Not Like Ours?
Feb 10, 2007 0 Replies
[TELECOM Digest Editor's Note: Once again, the 8-bit characters did
> not render correctly in this message. PAT]
The characters display perfectly well on my imac. Check your settings, Pat.
- Colin
[TELECOM Digest Editor's Note: The problem is, when I work on this Digest I use a terminal emulator (puTTY) to connect with massis.lcs.mit.edu. It is a 7-bit thing. PAT]
