> What this means is that if the wireless carrier gets numbers from rate
>> center A, wireline customers in rate center A will be able to port to
>> wireless and vice versa. Wireline customers in rate centers B, C, and
>> D will not be able to port to or from wireless because the wireless
>> carrier isn't present in their rate center.
> Really? My tiny ILEC says our numbers are portable to wireless, but
> there are no prefixes in their rate centers but theirs.
> I was under the impression that you really only need to be present in
> the LATA, not in the rate center, for portability to work. You just
> need to be able to provide a routing number for the portability
> database and as far as I can tell the routing number need not be in
> the same rate center as the original number. There's certainly no
> technical reason it has to be.
> Inbound calls will still be rated as calls to the original rate
> center, but cellular and VoIP carriers don't care.
John, thanks for pointing out that this issue is a bit more complicated than I let on. As you note, there is no technical imperative for portability to be limited to a rate center. A white paper on this is located at:
A wireline carrier must port to a wireless carrier even if the wireless carrier doesn't have numbering resources in the rate center where the number is located. The wireline carriers took the position that they didn't have to do so, but the FCC ruled in November 2003 that wireline-to-wireless ports were required as long as the wireless carrier has service covering the rate center (using Zip codes for that determination, apparently). It did not require wireless-to-wireline ports where the wireline carrier doesn't have numbering resources in the rate center where the ported number is located, however; that issue has been put on hold pending further study. The order is online at
Michael D. Sullivan Bethesda, MD (USA) (Replace "example.invalid" with "com" in my address.)
