Re: Is it Possible to Get a Shock From POTS/DS
Apr 19, 2006 0 Replies
My brother says he is occasionally getting a shock when using his wired
> phone (ATT Trimline) with DSL filter on a SBC POTS/DSL line. Is the > phone shorted?
If it was a true technical "short", meaning two wires are touching, the phone wouldn't work. Your brother is somehow making contact between the two wires coming into the phone, or between the hot wire and another ground. It may be possible that the receptacle into which the phone is plugged is wired backwards. It is likely that something is worn or touching the metal part of the phone; it shouldn't. Phones are so cheap, it isn't worth fooling with. Toss the thing in the trash and spend the ten bucks for a new one.
Lena
