George Berger writes:
>> A year ago, I called and asked for upgrade of our dial-up connection to
>> broadband cable.
>> I had already wired our home with a two-way splitter from the Comcast
>> cable entry to our home (which, by the way, provided -- and still
>> provides -- excellent TV reception). I used top-line Belden RG 59 cable
>> for the 20' run to our top floor den where we have our computer.
> FYI: RG-59 has an upper bandwidth pass of around 800-900MHz. Cable
> companies have long been using RG-6 for their installations which has
> an upper bandwidth pass up around 1.8Ghz.
Note that there is a lot of "RG-59" cable out there that isn't really RG-59 ... it's the same diameter and uses the same fittings, but it's much better than the specs in the Radio Guide require for the type.
I'm not sure what "top line Belden RG 59 cable" is, but if you give me the Belden part number on the side of the cable, I'll tell you.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
