Re: Can Verizon Phone be Used With Bell Mobility in Canada?
Jun 11, 2005 0 Replies
Can a Verizon phone be used with Bell Mobility in Canada? I know they
> both use CDMA. I am specifialy interested in the Kyocera 7135.
It all depends on BM's policies. Many CDMA operators will not allow you to use equipment (even if compatible) on their networks unless the ESN of the handset is in their database. I believe BM's policy is to not allow ESNs not in their database. I'm not sure if they do this to be obstinate or if there's some other reason. CDMA and TDMA operators are the only ones who do this. GSM operators don't care what equipment you use on their networks and for the end user all they need to know is that their handsets are not "SIM locked" i.e. the handsets have not been prevented from using another SIM by locking out other operator's SIMs.
