Re: 10base-T & POTS in same Cat-5 cable?
Apr 27, 2005 0 Replies
Is it acceptable to use 1 pair in a Cat-5 cable for POTS when 2 pair
> are being used for 10base-T? Wondering about cross-talk, etc.,
> introducing noise between these two.
> Thanks,
> Please, no "Go Google this" replies. I wouldn't
> ask a question here if I hadn't done that already.
> DaveC
> snipped-for-privacy@privacy.net
> This is an invalid return address
> Please reply in the news group
No problem if you use 10base-T , usually none on 100base-T, but not compatible if you plan to use or upgrade to 1000base-T which some computers switches and routers are now supporting.
