Where I live, it is possible to setup a call to virtually any destination number using the format:
[+] 1 - 611 - [NPA] - [NXX] - [XXXX]
and after a few unsuccessful attempts (diverted to intercept recording that references "0 7 7 P" at the end) ... calls will ring through.
These calls do not get billed, when using prepaid phone and activated SIM. If there are minutes on the balance, none are deducted; even with balance of $0.00 (!!!), calls are completed when dialing with the sequence. for the life of me, i cannot figure out WHY this works -- though I have some theories.
- anyone help me out with this ? *
Doesn't even make sense to me following the numbering plan information I am familiar with. Is it an international call ? Choke prefix (contest code) ? Priority access code (emergency preparedness type of thing) ?
It has been used for years, locally; some people, whose opinions I don't respect, have mentioned it in a network routing sense and associate it with satellites !
I think it's an error somewhere in the mobile switching center, but seems like it would have been corrected by now; considering ... it delivers unlimited calling for no cost to probably a lot more people than just me.
(Having already posted this question to howardforums and other such places, feedback from others has been limited to: "tried this over and over, didn't work! this guy's pulling our leg!" so cautionary word: don't waste your time trying if you're not in or around Portland, Oregon.)
-- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.394 / Virus Database: 268.10.1/391 - Release Date: 7/18/2006
[TELECOM Digest Editor's Note: And if you are around Portland, Oregon note what he said early on -- 'after a few unsuccessful attempts, calls will ring through ...' meaning the first few times, you may fail to connect. This sounds like a case where, if the timing is not _just perfect_ -- meaning some of your dialing signals reach a switch somewhere where they are expected exactly on time, or within a couple milliseconds of when they will be dealt with, the other switch accepts what it did recieve and acts on it instead (meaning you wind up getting a 'wrong number' [or no number at all] since you get told 'call cannot be completed as dialed' or words to that effect.)
I am reminded of the old 9928/9929 scam which worked in much the same way in Chicago years ago, for a few years. If you called
312-(any exchange)-9928 it would answer by extending dialtone from
9929 and then the device attached to 9928 would quickly pulse out '611' and release itself from the line. Your object was to cause your fingers to be quick enough to (upon hearing the dial tone extended by 9929) seize that dial tone and dial whatever you wanted in the three or so second interval before 9928 woke up and pulsed out '611' on you. If you got your seven or ten/eleven digits in there first, then the network began acting on your request and when 9928 woke up and tried to say '611' to the dialtone outbound on 9929 it was ignored. In other words, whoever got the dialtone first controlled the dialtone; if you both hit it at the very same instant, then the outbound got confused and usually wound up either producing a 'cannot be completed as dialed' or maybe a wrong number.
We knew which of the 9928s had the slower and 'more liberal' dialers on them and which of the 9928s were almost impossible to work with, meaning they responded so quickly with their rendition of 611 that they _always_ controlled the dialtone and all we could get was a 'cannot be completed' message if we did get a few digits into the audio stream in the process. A couple of the 9928s were very liberal; they would give you all of five seconds or so before they woke up and took over. For some of them, no matter how fast your reactions and your fingers, you just could not within the one or two seconds allowed between hearing outbound dialtone and the waking up of the device on 9928 manage to dial anything. I will not bore you with what it was used for; at one point in telco's past glorious history there was a reason that two sequential numbers in the 9900 series (almost always reserved exclusively for telco internal use) responded that way. As a hint, '611' used to be a three digit code used by subscribers to reach repair service. On cellular phones, either 611, *611, or 1-611 are usually used to reach voice mail at the cellular company customer service. You know, you dial '611' and a recording thanks you for calling Verizon customer service and press one to speak English, or press two for Pig-Latin, etc.
Now with cellular phones, there is no audible dial tone, and with voice mail systems -- such as cellco's own customer service, it usually is possible to 'break out' of voice mail, or do an 'operator- escape' to get you somewhere. You said this happens with a cell phone. What happens if you only give the phone '1-611' and nothing more? Do you wind up with the cellco's opening voicemail message? What happens if _some_ voicemail thing starts but you instantly break into whatever message it is and continue with dialing NPA, etc? I say 'instantly' and I mean _as soon as you hear the first syllable of the first word_. Does the voicemail recitation instantly stop at that point and maybe either ask something else of you, or say nothing and just sit there silently? If this happens, that 1-611 _only_ gets you to a voicemail (probably cellco) and tapping another key _at that point_ serves as an 'operator escape' from voicemail then the answer to your question is that you have inadvertently hacked cellco's voicemail to get an outside line and the reason it takes no minutes off of your account is because cellco does not charge 'itself' for outgoing calls.
If you have a caller-ID box there, try your experiment again with
1-611-NPA-the number of your own landline with caller-ID on it and if/when the system (it sounds like it is rather sensitive) completes the call and rings your own landline phone back at you, note from the caller-ID 'who is calling'; I'll bet you anything it is NOT the number of your cell phone but a number from cellco's switchboard or whatever they use for incoming calls post-voicemail greeting. The reason it sometimes fails to complete as desired is because the timing of your cell phone, the cell tower, and wherever 611 or 1-611 terminates is not exactly as precise as it should be.
It is _not_ an 'error in the mobile routing center' as you put it; it is instead a situation where some devious beady-eyed phone phreak at some point or another in the past discovered a way to break out of cellco's voicemail and make phree phone calls. And he discovered, or already knew that by dumping the entire string in at once at the beginning 1-611-NPA-etcetera it would shut off the audio path back to him until the dialing had completed and the call started to set up at some point. See if this helps you any. PAT]
