Wall Mount Outdoor Dome Camera
Apr 10, 2006 1 Replies
Looking for suggestions for a good, but affordable, outdoor, wall mounted, color dome camera setup. Camera should be a fixed, day color/night bw, at least 480 lines resolution that can be pointed, with adjustable focus. Intended for outdoor commercial location looking down the side of the building. The key is that it has to be wall mounted on an arm type bracket.
Would like to keep the cost under $750.00, and closer to $500 if possible. I know this doesn't buy much, but this is the budget I've been given.
Thanks,
Bossman
Look here:
These have a gimbal bracket and may not need a mount. And they're not very expensive.
Or these:
with this mount:
js
