Scantronic 9800 Installation Manual
Jul 05, 2006 2 Replies
Following a frantic 15 minutes last night, disconnecting batteries and power supplies from all parts of my 9800 system, I now have a quiet household. The original problem was the failure of the battery in the main control unit which, as is well documented, causes the internal alarm to go off every couple of minutes even if you type in the user code (why???!!!). To top it all it caused me to miss the end of the footy ; (
Anyway... I now have a dead system, and will buy a new battery to fix it, however I get the impression I will need the installation manual to do this. Even if not, I would really like a copy of one to hand in case of future problems. Can anyone oblige? I've seen posts from a couple of years ago that suggest there are people out there prepared to share...
many thanks
I emailed you a copy.
Jim Rojas
Thank Jim : )
Iain
Jim Rojas wrote:
