running as local system ADT Focus 200
Aug 08, 2013 1 Replies
Moved into a commercial space with a 2 zone 2 keypad Focus 200 installed ( back in 1999). Motion sensors light are on, and I guessed correctly the user I'd code. So if I unplug the phone line from the brown box can I use this as s local system for now , until we get a local company in to upgrade?
possibly as long as line cut detection is not in use local alarm would work and keypad might beep if there is an alarm due to failure to communicate
