IP based alarm systems/ access control ?
Sep 12, 2005 7 Replies
Crash Gordon
Man, that is one U G L Y keypad, reminds me of an electric shaver from the 50's or something...I wonder what designer came up with that?! | | > Anyone know of any IP based access control and or alarm systems, Ideally | > power over Ethernet powered. | > | > thanks | > | > S | |…
Anyone know of any IP based access control and or alarm systems, Ideally power over Ethernet powered.
thanks
S
. Check out the Elk M1-Gold.
| > thanks | >
| > S | | |
. Check out the Elk M1-Gold. | | |
It does look better in real life but yes it isn't the best looking keypad out there
It looks to me more like a mini version of those jukeboxes you used to see in booths in restaurants.
I can't for the life of me, think of any application where you would either need to, or want to send power over Ethernet to power a control panel. You wouldn't be able to go the distance, nor have enough amperage to power much of anything. Sounds like you're mis-understanding the concept of PoE, and the limitations.
