I am trying to hook up a 2 wire smoke detector to a DSC 832 panel. I can't find the location of the CON1 jumper that I need to remove. Any tips would be appreciated.
DSC 832 Panel CON1 Jumper Location?
Mar 07, 2006
Middle of the board, slightly left of center. I need to put my specs on to find it. :-) js
I found it. Boy was this well hidden. On my board, it was labeled JP1. The DSC documentation sure leaves a lot to be desired.
Thanks for the help.
Mike Schumann
Indeed, along with quality control, dealer service, etc.
"Robert L Bass" a écrit dans le message de news: snipped-for-privacy@4ax.com...
look who's talking,,mister cant answer the phone or answer email...
There is nothing wrong with the DSC documentation, you have a v1 board and the manual is for a v2 board
Yet you continue to sell it
I have to hunt for it every time, and I KNOW where it is.
Heh, you should try Ademco. js
With few exceptions, and given the amount of DSC I use, I have had very little trouble with it. Certainly no more than with any other brand.
Since you do not install yourself, I take it your observation is based on the experiences of your DIY diciples. Perhaps they are challenged in some way. js
you mean Napco right?
The manual and panel came together in a factory sealed DSC box.
Mike Schumann
There's nothing wrong with that, right? The above is an example of DSC's ongoing program of quality control "improvement". :^)
Er, yeah. Napco. That's what I meant. js
Yup, 3 manuals
