can garage door safety beam signal an alarm system (napco 9600) the beam was tripped?
Aug 10, 2005 1 Replies
Robert L Bass
I'm not familiar with the Stanley system but my door opener has a similar type safety beam. The beam has a closed circuit output (opens on interruption of the beam). If yours is like mine it would be trivial to connect it to a home automation system such as the ELK M1 Gold.…
I have a Stanley garage door opener with a safety beam. I know it prevents the door from closing if the beam it tripped. Can you also setup a security zone to monitor its state? Not really needed from a security perspective but would like to know via my home automation system if it's tripped or the sensor was knocked out of place.
Thanks
I'm not familiar with the Stanley system but my door opener has a similar type safety beam. The beam has a closed circuit output (opens on interruption of the beam). If yours is like mine it would be trivial to connect it to a home automation system such as the ELK M1 Gold. Connect the output of the beam to a spare zone on the HA system. Program a relay to follow the status of the beam (that is, transfer the relay whenever the beam is broken). Also program the system to give whatever kind of alert suits your need if the beam trips. You might also want to bug the overhead door itself.
Regards, Robert L Bass
