cameras in a car?
Nov 17, 2005 5 Replies
Rich
A 12 time laps recorder in the trunk. A Mimi cam in a Kleenex box on the back deck. A mini cam in the fussy dice from the front visor. You could go wireless to the house.
cameras in a car? open original image
Hi All,
I'm having a bit a problem with some local hoods. I need a two camera system for my car that covers the front and rear. An additional microphone channel would be nice if possible. I don't want the cameras or mic to be readily identifiable - the goal is to get good quality video of the status quo. Time and date stamp on the recorder would be nice if possible.
Is anything available under $1000 that will do this? I'm really concerned about adapting off-the-shelf components because of the environment in a car
- heat, vibration, etc.
Any ideas appreciated.....
Like the other reply states cameras can be hidden in any object. Wooly hat,
1x glove on dash, cleenex (like stated) air freshner. There are plenty of 12 volt 4 camera DVRs that are available, you don't need to worry about vibration if you only use it when vehicle is parked.
Check out
. The "Oh No" episode is the funniest.
Hi, I am not sure about price, but look
i think they have what you need.
Chris
Try here:
