Z-WAVE question
Apr 22, 2006 22 Replies
Here's some more contact info. Hope it helps.
Zensys Inc. - Headquarters
535 Middlefield Road Suite 245 Menlo Park, CA 94025 USA Tel: (650) 853-7000
Zensys Inc. - Sales One Park Way Upper Saddle River, NJ
07458 USA Tel.: (201) 785-1940 Fax: (201) 785-1946
For general information: snipped-for-privacy@zen-sys.com Concerning our products and services: snipped-for-privacy@zen-sys.com
The M1XSP is the M1 serial expansion port:
The firmware was released to the public for beta testing a few months ago, it is on the support site:
And you can discuss it/get support there or at Cocoontech:
The quality of the product is beta (like most of Insteon right now, sadly). Fortunately, Elk is committed to supporting Insteon, they have a good relationship with SmartHome/SmartLabs.
Which makes purchasing the product from SmartHome the wiser course. Their technical support would be all the more current on the latest developments vis-a-vis the Elk/Insteon technilogical "merger". Thanks "none" for the helpful links.
Frank Olson
