Omni Pro and SmartLinc IR
Aug 04, 2005 3 Replies
Jump to replies (3)
I have the HAI OmniPro II which I would like to operate my home theater systems ( TV, Cable,DVD, Video, CD player and HVAC system).
I would like to connect the 10A17 ( Serial Module) and to connect RS232 to IR transmitter.
I thought about using xantech or Smartlinc IR transmitter with 6-8 emitters. I tried to look for schemes and products but found none.
Where can i get more details about it?
Best regards
Oren
Have you thought about using an Adicon Leopard / Ocelot? The Worthington site has an article on how to integrate it w/ an HAI Omni:
Kurt
I'd certainly look at using the HAI thermostats for the HVAC control. I've found them to be extremely nice and flexible.
Chip
Like Leviton SnapLink Mobile App, NQLink work with Leviton Security&Automat ion Omni/Lumina familly Controller. NQLink use latest technology for connec tion and data processing, NQLink much faster on connect than other app that you ever seen.
NQLink Provide both connection Local IP and Outside IP or domain name with one account for all devices: Controller, Hi-Fi2, Music Sever, Camera. App a utomatically looking for available connection every time. if you switch you r phone between Local wifi to cellular data network, NQLink automatically s witch connection also.
NQLink can run in background and start with your phone reboot to give you o ption notification on system such as: Security Mode, Lighting changed state .,etc.
NQLink Supported widget for function, GEO Fencing based on GPS Technology, Camera JPEG, MJPEG and RTSP H264/H265 format.
Feature:
  • Two option for display: List display and Grid Display (Touchscreen displa y mode)
  • Two connections Local IP and Domain name (Outside IP) supported
  • Looking for available connection automatically
  • Notification option for report system event
  • GPS GEO Fencing function
  • Voice control supported (Require Internet connection)
  • Supported HAI Music Gateway and Music Server
  • Supported Hi-Fi2 Equalizer Setting
  • Control light and Appliance.
  • Security management.
  • Air Conditioner Management
  • Multi Room Hi-Fi2 Audio system.
  • Macro Button Control
  • User Setting
  • Access Control
  • Room and Area manage by Users
  • Camera JPEG, MJPEG and RTSP H264/H265 format.
  • Press and hold Item desire to Re-name (Please enable Display as list in A ccount setting)
Comercial version:
ller
