Need help using Visual Baisc 6 and x10
Dec 30, 2006 4 Replies
Jump to replies (4)
I want to write a VB6 app which will control dimming/on/off of various strings of lights for a (next) Christmas project. Can someone direct me or get me started with some VB code that controls some X10 modules. Please help me with the right libraries or syntax for controlling a USB sending unit. It would be great if I could create the commands and then upload them to an "uploadable" x10 unit. My e-mail is snipped-for-privacy@adelphia.net Any help is appreciated.
What x10 controller are you using?
The > I want to write a VB6 app which will control dimming/on/off of various
AZ: I haven't purchased anything yet. I'm looking for the right advice. Do you have any VB code to show me? bob
There's also an sdk for the cm15a on the x10 website (x10.com). I've not used VB, but did write an interface in C running under Linux.
-mhd wrote:
