KNXLive! an open soirce alternative to ETS
Sep 14, 2006 2 Replies
Hi to all.
I'm newby on home automation but not in embedded system. After some research on BUS technology I chose to start from KNX (for the fully complies to the EN 50090 series, the European Standard for Home and Building Electronic Systems and ISO/IEC 14543). I chose KNX also for high availability of devices producers (as ABB and Siemens). But when I tried to search for system programming and integration I found that all people talking about the use a commercial software (ETS) and API(Falcon) made from KNX Association
). I'm disappointed: open standard and closed resources...
...but other search...
and I found an open alternative based on Linux OS, called KNXLive!
). I enjoyed...
KNXLive is based on Knoppix 3.9 The CD contains, pre-installed and ready to run: - A BCU1/PEI16 device driver - An EIBnet/IP Tunnelling server ("Tweety"), which uses a BCU 1 with serial interface for EIB access - A Java Library ("Calimero") for accessing EIBnet/IP Tunnelling servers, handling group data exchange using popular data point types and maintaining a simple point database - A graphical demonstration client for Calimero - A tool set for writing and downloading BCU applications, RAD-style ("BCU SDK") - The powerful EIB access daemon ("eibd") of the BCU SDK
I'm studying this system and BCU SDK, a set of tools useful for programming BCU
). I start this new topic to collect experiences and opinion about this ETS alternative
Good work... See you soon
Hi to all.
). I enjoyed...
I'll add this information to my pages in a few days. Good work and thanks!
